Введение
This guide will help you replace your cooling fan. Throughout this troubleshooting guide there are no special requirements or hazards present. There is little to no risk of injury involved to complete these guide steps. Read thoroughly through all guide steps before starting the action.
Выберете то, что вам нужно
Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
Insert the plastic opening tools into the seam on the back plate of the laptop.
Pry the back plate up.
Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
Еще один человек закончил это руководство.
