Введение
The keyboard is an input peripheral/interface on your device that will occasionally have keys stick or not function properly. Follow the steps below if you need to replace the keyboard on your MSI GT70 MS-1763. Keep in mind that the keyboard must be replaced as a single unit. The MPN is
S1N-3EUS204, V139922AK1
Выберете то, что вам нужно
Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
Remove the back cover.
Using a Jimmy, remove the outer cover around the keyboard.
Remove the ribbon cable from the ZIF connector on the underside of the top cover.
Using a Phillips #0 screwdriver, remove the five 3 mm screws at the top of the keyboard.
Flip the laptop over and disconnect the data cable from the ZIF connector on the bottom right.
You can now turn the laptop back over and remove the keyboard.
