Введение
This guide will help you replace the screen of your MSI GT70 MS-1763 laptop. We will walk you through the steps to remove your screen in order to replace it.
Выберете то, что вам нужно
Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
Remove the rubber guards covering the two 3mm screws on the bottom of the screen. Next, remove the screws with a Phillips #0 screwdriver.
Remove the six Phillips #0 screws holding the screen in place.
Separate screen from the assembly with a Jimmy.
Remove the display cable from its connector on the back of the screen.
Remove the screen.
Еще один человек закончил это руководство.
