Введение
The battery is the energy source for this computer. A battery can loose the about of charge that can be obtained over time. This will lead to the need of a new battery.
Выберете то, что вам нужно
Remove the four screws from the back cover using the Phillips #0 screwdriver. Screws are 0.5 inches long.
Unplug the battery, then using the black nylon spudger, carefully remove it from the laptop. It is held down by an adhesive, but can be safely removed without damaging the device.
