Введение
RAM (Random Access Memory) is a crucial component to your computer system. Sometimes, a RAM card can become corrupted. To fix this, the corrupted RAM card must be replaced.
Инструменты
Запчасти
Детали не указаны.
Unscrew each of the four screws using the Phillips #0 head on the back of the laptop case. The screws are 0.5 inches in length.
Lift and remove RAM card by hand. Replace each RAM card and test them individually. If your computer encounters a RAM error with only one card inserted, you can confirm that card is corrupted.
Почти готово!
Заключение
