Введение
This guide will show you how to replace the hard drive inside of the MSI PE70 6QE-035US. If your device is struggling to download new files or applications, replacing your hard drive could be the fix to your problem. Be sure to follow this guide on any hard surface or area that won't create any static electricity.
Выберете то, что вам нужно
Start by flipping the device over to the backside.
Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
After removing the back panel, unscrew the Hard Drive using the PH0 bit.
Set old drive aside, and grab the new Hard Drive
Еще один человек закончил это руководство.
