Введение
Are you having trouble running programs and require a RAM replacement? Or maybe just looking to replace your current RAM sticks with others? This guide will show you all the steps on how to do so. All you will need is the J0 size bit, an Ifixit screwdriver, and any hard surface ground or area that will not create static electricity.
Выберете то, что вам нужно
Start by flipping the device over to the backside.
Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
After you remove the back panel, you should now see the RAM
Pull the tabs holding in the RAM outwards. The RAM sticks should pop slightly outward and can now be removed.
To reassemble your device, follow these instructions in reverse order
2 участников успешно повторили данное руководство.
