Mac Cube G4 205W Power Supply Disassembly
Выберете то, что вам нужно
  1. Mac Cube G4 205W Power Supply Disassembly, Mac Cube G4 205W Power Supply Disassembly: шаг 1, изображение 1 из 1
    • First things first : you'll need a reasonably dead Mac Cube power supply
  2. Mac Cube G4 205W Power Supply Disassembly: шаг 2, изображение 1 из 3 Mac Cube G4 205W Power Supply Disassembly: шаг 2, изображение 2 из 3 Mac Cube G4 205W Power Supply Disassembly: шаг 2, изображение 3 из 3
    • The first step is to separate these two end-caps
    • Each of them has 2 very strong (and equally brittle) clips holding it in place
  3. Mac Cube G4 205W Power Supply Disassembly: шаг 3, изображение 1 из 1
    • The only way to access these clips is through the ventilation holes, .. how convenient !
    • It's enough to unhook 1 clip per side, and one of the clips cannot be unhooked, as it's blocked by some black paper plastic rubber thingy
    • It is highly recommended you go in through the marked holes (those are the largest open areas inside the PSU anyway)
    • In case you have something thin and strong enough to do this without enlarging the holes: please leave a comment down below !
    • I drilled through the existing holes to make them large enough for a fittingly stiff screw driver
    • BEWARE : this plastic is incredibly brittle and will crack very easily; using a stepped drill bit for the plastic, then a regular bit for the metal worked best
  4. Mac Cube G4 205W Power Supply Disassembly: шаг 4, изображение 1 из 2 Mac Cube G4 205W Power Supply Disassembly: шаг 4, изображение 2 из 2
    • Once you've enlarged your holes, it's just a matter of carefully prising these clips free
    • Again, be careful, they're very brittle
    • Since peeping through a 3mm hole doesn't give one the best visibility, here's also a photo of the power supply board, so you know what to look out for ;)
  5. Mac Cube G4 205W Power Supply Disassembly: шаг 5, изображение 1 из 1
    • Correctly assuming you've gotten rid of all the plastic surrounding the metal chassis, it's high time to open a bottle of something !
    • Unclip metallic end-caps with a relatively skinny flat-head screw driver
  6. Mac Cube G4 205W Power Supply Disassembly: шаг 6, изображение 1 из 1
    • Now, the last step is to unhook the two halves of the metal chassis from each other - with the correct motion, this happens very easily
    • Firmly press on the top half (the bottom has the PCB laying right against it) whilst prising with a flat-head screw driver at the seam: there's 3 metal clips to unhook on each side
    • And you're done !
    • Feel free to share what problem yours had and how you've fixed it down in the comments :)
Заключение
Congrats !
2 участников успешно повторили данное руководство.
Darie H
Участник с: 11/20/12
4 550 Репутация
Автор 5 руководств
2 Комментариев
Excellent walk-through of the steps, with very kind and generous warnings. I found this VERY helpful, as I own two working G4 Cubes, with no power supplies. I’m looking for broken “bricks” to repair and finally re-use my Cubes.
Scott Peaker - Ответить
Thanks mate ! This will help to get my Cube alive again : -)
Pumpkin Eater - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 21
За всё время: 1,693
