Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Tilt the mini enough to allow the bottom cover to fall away from the outer case.
Remove the bottom cover and set it aside.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
Lift the fan out of the mini for enough clearance to access its connector.
Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
Remove the fan.
23 участников успешно повторили данное руководство.
2 Комментариев
How do you know the order of the wires when placing the 4 wires back onto the motherboard?
The connector is a snap in / snap out or more properly lift out connector. The connector goes back in only one way with the 4 pins aimed towards the wifi icon. To get it out you GENTLY lift the wires. I used my fingernail under the wires as they went from the fan into the connector.
