Введение
If your Mac Pro has a scratched or damaged case, here is a tutorial to completely replace it.
Everyone can do it, but the disassembly and reassembly are very long steps. Patience is the key to success.
Инструменты
Запчасти
To open the Mac Pro, you'll have to lift the clip on the back of the case
Having the flap in the high position, the panel should separate from the box without force
You then have to remove the hard drives. It is simple: pull them towards you with a bit of force.
Very simple, pull the DVD drives towards you, it should come out with a little force.
On the power support there is a button, press it and you can move the power supply to the left (see picture)
You have to pull the graphics card towards you to take it out of the box
With a screwdriver unscrew the two screws that hold the fan bracket to the board
Pull the fan towards you
Behind the fan bracket there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
With a H3.0 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
Remove the clip at the top of the fan
Pull on the top of the fan a bit.
Similar to the top remove the clip at the bottom and pull out the fan.
Disconnect the 2 x 4pin fan cables and the 1 x 2 pin speaker cable
Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
Follow the steps in reverse to resemble.
Great instructions.
Easy to follow
Thanks for posting this teardown! Worked out great!
Used this to replace all the cooling fans in my macpro5,1
To resemble, follow the instructions in the reverse order.
18 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Danпомогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Комментариев: 5
Bonjour, j’ai un mac pro 5,1 de 2010 dont les clapets (ou les trappes, j’ignore le terme exact) de la baie des lecteurs de disques restent ouverts à chaque fois qu’ils sont actionnés. Je n’ai pas réussi à les démonter, et les 2 gouttes de 3 en 1 sur les glissières latérales n’ont rien changé au problème. Je n’ai trouvé aucun tutoriel, ni même aucune occurrence de ce problème sur le web. Pourriez-vous me donner quelques conseils ? Merci.
Amazing explanations and perfect picture track on each move made.
Thanks much - this was very helpful :)
Dennis.
Hello sir , I have a problem with my Mac Pro 5,1 mid 2010 Xeon 6core Cpu 64 GB Ram RX580
I erase SSD Hard Drive and I want to reinstall mojave OS and it does not work still appear ‘Missing Operating System’
I try to use all commends on startup like (Option) (Commend+R) (Option+Commend+R)(Option+Commend+R+P) and more commends
but nothing work with it … please I want help . I need your help please , please …
You’d probably get an answer a lot quicker if you just posted that as a question.
Evan -
Thanks for posting this guide!
I used it to replace all the cooking fans in my macpro5,1. Worked great!!
