Введение
Removing a PCIe or graphics card from this version of the Mac Pro isn’t as simple as pulling the card out of the PCIe slot.
Инструменты
Запчасти
Детали не указаны.
The screws are spring-mounted and will stay attached to the cover. You can remove them by hand, although a screwdriver may be needed to start.
If the card is long enough to reach the slots in the fan casing, or the card is hooked into the lock bar next to the PCI ports, you need to slide the cover on the fan casing over.
Press the release button and slide the casing to the left.
This also moves the lock bar.
2 участников успешно повторили данное руководство.
