Mac Pro Late 2013 AC Socket Replacement
Выберете то, что вам нужно
  1. Mac Pro Late 2013 AC Socket Replacement, Outer Case: шаг 1, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement, Outer Case: шаг 1, изображение 2 из 2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 AC Socket Replacement: шаг 2, изображение 1 из 3 Mac Pro Late 2013 AC Socket Replacement: шаг 2, изображение 2 из 3 Mac Pro Late 2013 AC Socket Replacement: шаг 2, изображение 3 из 3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 AC Socket Replacement, Fan Assembly: шаг 3, изображение 1 из 3 Mac Pro Late 2013 AC Socket Replacement, Fan Assembly: шаг 3, изображение 2 из 3 Mac Pro Late 2013 AC Socket Replacement, Fan Assembly: шаг 3, изображение 3 из 3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
    You don't have to remove the fan assy to get to the wifi board & card. It can be done with the fan assy still attached.
    Fat Mango - Ответить
    Fat Mango is correct. That said. If you do pull the fan assembly note that the screws are all held in with blue Permatex and breaking them free takes a fair amount of effort. Getting a good set of Torx screwdrivers is a must.
    Jim WIlson - Ответить
    Hey guys, what would happen if you only replace one card.. I have a D300 but the plan is to upgrade to D500 or D600. So If I can afford and install one instead of the pair would it increase something? or will it cause any conflict? I guess I don’t understand if I the Mac Pro has 2 D300 graphic cards that means each has 1GB? Same as If I would Install 1 D600 that would increase 3GB only? Thanks.
    marcotamayo - Ответить
    D300 = 2GB each card. Very few apps uses two cards at the same time.
    Gio Cas -
    The (5) Screws are Apple part number 923-0713
    Steven Gier - Ответить
  4. Mac Pro Late 2013 AC Socket Replacement: шаг 4, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 4, изображение 2 из 2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 AC Socket Replacement: шаг 5, изображение 1 из 1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
    On my Mac Pro (assembled mid-2017) these are T8 screws. In fact, there were no T7 screws anywhere in my machine.
    mark33 - Ответить
    There was no bracket on top of the cable at all, so I got a bit confused, so I had to skip step 5 and 6.
    Rakesh - Ответить
    On my machine, a TR7 worked to remove them due to the weird angle.
    Wilson Gaberino - Ответить
  6. Mac Pro Late 2013 AC Socket Replacement: шаг 6, изображение 1 из 1
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 AC Socket Replacement: шаг 7, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 7, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 AC Socket Replacement: шаг 8, изображение 1 из 1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
    You don't have to remove the fan assy to do the steps below. They can be done with the fan assy still attached.
  9. Mac Pro Late 2013 AC Socket Replacement, Lower Case: шаг 9, изображение 1 из 3 Mac Pro Late 2013 AC Socket Replacement, Lower Case: шаг 9, изображение 2 из 3 Mac Pro Late 2013 AC Socket Replacement, Lower Case: шаг 9, изображение 3 из 3
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Mac Pro Late 2013 AC Socket Replacement: шаг 10, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 10, изображение 2 из 2
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Mac Pro Late 2013 AC Socket Replacement, Interconnect Board: шаг 11, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement, Interconnect Board: шаг 11, изображение 2 из 2
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Mac Pro Late 2013 AC Socket Replacement: шаг 12, изображение 1 из 3 Mac Pro Late 2013 AC Socket Replacement: шаг 12, изображение 2 из 3 Mac Pro Late 2013 AC Socket Replacement: шаг 12, изображение 3 из 3
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    • Repeat this procedure on the other graphics card.
  13. Mac Pro Late 2013 AC Socket Replacement: шаг 13, изображение 1 из 1
    • Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
    These are actually 6.0mm T8 Torx Screws. 12/07/2016.
    Todd - Ответить
    Ended up being T9 screws for me.
    Nathaniel Wilson - Ответить
    mark33 - Ответить
    These are T8 screws in my 2013 Mac Pro.
    Sangers - Ответить
    T8 screws for me, i did and edit to this step
    Steve McGinn - Ответить
    Ended up being T15 screws on my machine
    Spencer Curtis - Ответить
  14. Mac Pro Late 2013 AC Socket Replacement: шаг 14, изображение 1 из 3 Mac Pro Late 2013 AC Socket Replacement: шаг 14, изображение 2 из 3 Mac Pro Late 2013 AC Socket Replacement: шаг 14, изображение 3 из 3
    • Gently walk the interconnect board straight up off the logic board's slot connection.
    • It is recommended to lift one side and then the other.
    • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
  15. Mac Pro Late 2013 AC Socket Replacement: шаг 15, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 15, изображение 2 из 2
    • Flip the interconnect board up and over, exposing the IO board data cable.
    • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
  16. Mac Pro Late 2013 AC Socket Replacement: шаг 16, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 16, изображение 2 из 2
    • Use the flat end of a spudger to separate the other side of the IO board data cable.
    • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
  17. Mac Pro Late 2013 AC Socket Replacement, Power Supply Assembly: шаг 17, изображение 1 из 1
    • Flip the Mac Pro back over and set it gently on a flat surface.
    • We recommend laying the Mac Pro on the corner of the heat sink and the two standoff screw posts that attach to the interconnect board.
  18. Mac Pro Late 2013 AC Socket Replacement: шаг 18, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 18, изображение 2 из 2
    • Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
    those are t4 screws in my mac
    Andrzej Kiryluk - Ответить
  19. Mac Pro Late 2013 AC Socket Replacement: шаг 19, изображение 1 из 1
    • Remove the power supply cage from the top of the power supply.
    • By removing this cage, you are exposing internal components of the power supply. Be very careful not to touch any of the power supply components or circuitry.
    • Be careful not to drop any screws or tools into the power supply, as this may damage the power supply.
  20. Mac Pro Late 2013 AC Socket Replacement: шаг 20, изображение 1 из 1
    • Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
  21. Mac Pro Late 2013 AC Socket Replacement: шаг 21, изображение 1 из 1
    • Remove the power supply assembly from the Mac Pro.
  22. Mac Pro Late 2013 AC Socket Replacement, Power Supply: шаг 22, изображение 1 из 3 Mac Pro Late 2013 AC Socket Replacement, Power Supply: шаг 22, изображение 2 из 3 Mac Pro Late 2013 AC Socket Replacement, Power Supply: шаг 22, изображение 3 из 3
    • Use the flat end of a spudger to disconnect the power supply DC-Out connector from its socket on the IO board.
    • Use the tip of a spudger to disconnect the power supply data cable from its socket on the IO board.
    • For both cables, make sure to pry straight up on the connector, and not the socket.
    Need to add T9 Torx Screwdriver to list of tools at the beginning of this article.
    htiek nworb - Ответить
    When I gently pried up on the power supply data cable, the entire socket came right off the board. Now what?
    rwcinmsp - Ответить
    Bought a new I/O board and got it back together. This little socket is held in only by 4 tiny solder joints. Suggest pressing down on the socket with a finger while gently prying up on the plug that snaps into it. (When reassembling, it presses in vertically.)
    rwcinmsp - Ответить
  23. Mac Pro Late 2013 AC Socket Replacement: шаг 23, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 23, изображение 2 из 2
    • Remove the four 9.0 mm silver T10 Torx screws from the sides of the power supply.
    • The power supply overhangs these screws somewhat, so you'll need to use a fixed screwdriver at a bit of an angle.
    I managed to untie the screws at an angle using the T9 screwdriver (instead of the T10) works well.
    Rakesh - Ответить
    awesome. thank you for the tip!!
    samuel culper - Ответить
    A T-10 tip used with a 4mm or 5/32” open-end wrench to loosen helps, too. (These really should be hex bolts…)
    MotorMac - Ответить
  24. Mac Pro Late 2013 AC Socket Replacement: шаг 24, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 24, изображение 2 из 2
    • Gently shift the power supply to free the AC power inlet cable out of its plastic clip.
    • Be careful not to try to separate the power supply from the IO board assembly just yet, as it is still connected by the AC power inlet cable.
  25. Mac Pro Late 2013 AC Socket Replacement: шаг 25, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 25, изображение 2 из 2
    • Flip the power supply back to expose the AC power inlet cable.
  26. Mac Pro Late 2013 AC Socket Replacement: шаг 26, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 26, изображение 2 из 2
    • Squeeze the AC power inlet cable connector and pull it straight out of its socket in the power supply.
  27. Mac Pro Late 2013 AC Socket Replacement, IO Board: шаг 27, изображение 1 из 1
    • Remove the two 9 mm silver T10 Torx screws securing the IO Board to the IO shield.
    On reassembly, before tightening these 2 9.0mm T10s, make sure the other 4 holes line up. Otherwise you might be setting yourself up for cross threading the 4 remaining 9.0 mm T10 that are already in a bad spot for torquing.
    Might not be a bad idea to put the other 4 halfway in to be sure no resistance, then tighten the 2 in this step, then remove the other 4.
    is - Ответить
  28. Mac Pro Late 2013 AC Socket Replacement: шаг 28, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 28, изображение 2 из 2
    • Lift the IO board up from the IO shield from the end with the AC plug.
    • Do not attempt to completely separate the IO board from the IO shield, as there are still two cables connecting the two components.
  29. Mac Pro Late 2013 AC Socket Replacement: шаг 29, изображение 1 из 3 Mac Pro Late 2013 AC Socket Replacement: шаг 29, изображение 2 из 3 Mac Pro Late 2013 AC Socket Replacement: шаг 29, изображение 3 из 3
    • Set the assembly down on a flat surface to access the connectors on the IO board.
    • Use the tip of a spudger to flip the retaining flap on the IO shield ribbon cable ZIF connector.
    • Disconnect the IO shield ribbon cable.
    This step is unnecessary as you can access the battery already.
    Gary Sheppard - Ответить
  30. Mac Pro Late 2013 AC Socket Replacement: шаг 30, изображение 1 из 2 Mac Pro Late 2013 AC Socket Replacement: шаг 30, изображение 2 из 2
    • Squeeze and pull the audio jack ribbon cable connector from the IO board.
  31. Mac Pro Late 2013 AC Socket Replacement, AC Socket: шаг 31, изображение 1 из 1
    • Remove the four 6.5 mm T4 screws (with washers) from the flange around the AC socket.
  32. Mac Pro Late 2013 AC Socket Replacement: шаг 32, изображение 1 из 1
    • Remove the AC socket from the IO panel.
Заключение
4 участников успешно повторили данное руководство.
Andrew Optimus Goldheart
Участник с: 10/17/09
502 825 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
Один комментарий
Does anyone know where to purchase the screw sets for the Mac Pro?
Andre Pacheco - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 14
За последние 30 дней: 54
За всё время: 7,319
