Введение
Use this guide to replace the AirPort card in your Mac Pro Late 2013.
Инструменты
Запчасти
Детали не указаны.
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
While supporting the fan assembly with one hand, loosen the two T7 captive screws in the fan cable bracket.
Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
Disconnect the fan assembly antenna cable from the IO board.
Remove the fan assembly from the Mac Pro.
Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
Remove the fan assembly lid.
Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
Remove the fan assembly ribbon cable from its ZIF socket.
Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
Disconnect the fan ribbon cable.
Use the tip of a spudger to disconnect the four AirPort antenna cables from the AirPort card.
Remove the two 3.7 mm T4 Torx screws securing the AirPort card to the AirPort board.
2 участников успешно повторили данное руководство.
Комментариев: 3
Is there a way to replace the Mac Pro Airport card with a more recent one, like when you insert a recent one in an old macbook pro to get new features such as "unlock my mac with my apple watch" ? This is an interesting question that remains unanswered (until now ?)
