Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Slide the lock switch to the right, to the unlocked position.
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
Disconnect the fan assembly antenna cable from the IO board.
Remove the fan assembly from the Mac Pro.
Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
Carefully lift the lower case up and remove it from the Mac Pro.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Gently separate the other side as well.
Flip the connector up and out of the way of the graphics card.
Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
Gently walk the interconnect board straight up off the logic board's slot connection.
Flip the interconnect board up and over, exposing the IO board data cable.
Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
Use the flat end of a spudger to separate the other side of the IO board data cable.
Bend the cable out of the way and remove the interconnect board from the Mac Pro.
Flip the Mac Pro back over and set it gently on a flat surface.
Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
Remove the power supply cage from the top of the power supply.
Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
Use the flat end of a spudger to disconnect the power supply DC-Out connector from its socket on the IO board.
Use the tip of a spudger to disconnect the power supply data cable from its socket on the IO board.
Remove the four 9.0 mm silver T10 Torx screws from the sides of the power supply.
Gently shift the power supply to free the AC power inlet cable out of its plastic clip.
Flip the power supply back to expose the AC power inlet cable.
Squeeze the AC power inlet cable connector and pull it straight out of its socket in the power supply.
Remove the two 9 mm silver T10 Torx screws securing the IO Board to the IO shield.
Lift the IO board up from the IO shield from the end with the AC plug.
Use the tip of a spudger to flip the retaining flap on the IO shield ribbon cable ZIF connector.
Disconnect the IO shield ribbon cable.
Squeeze and pull the audio jack ribbon cable connector from the IO board.
Use the tip of a spudger to pry the CMOS battery out of its socket.
26 участников успешно повторили данное руководство.
11 Комментариев
A very good guide. I have a few notes from my experience replacing my battery.
In step 13 the torx screws securing the interconnect board to the heat sink were T-8 on my Mac but T-7 worked.
In step 23 a short arm Torx key would be helpful. Getting them out tore up the heads of the screws and getting back in was difficult without cross threading some of them. Bondhus (model no. 31832) sells a set that might help.
In step 29 if you don't reconnect the power supply data cable completely your Mac fan will run full speed and the processors will max out.
Yeah, could somebody please post the specifications for the replacement battery and maybe a source for it?
From the tear down, it's a Long-life BR-2032... I got mine at: https://www.amazon.com/PANASONIC-BATTERI.... Good luck! Great machine!
Yes, the BR2032.
The difference between it and the CR2032 medical battery is the wider heat tolerance range, both extreme heat and cold of the BR. As these are known to get quite hot, get the BR2032.
The batteries in most Macs are easy to replace so substituting the common CR2032 works fine. Electrically, they are identical. The Mac Pro and the late 2009-2010 iMac are a bit time consuming (2009–10 iMacs have the battery on the back of the motherboard) so use the same one that Apple uses.
