Введение
Use this guide to strip and replace the outer case of your Mac mini Late 2014.
Выберете то, что вам нужно
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
Carefully pull the antenna cable out from the gap between the power supply and case.
Remove the two 12 mm T6 screws from the fan.
Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
Lift the fan straight up to free the captive screw from its hole in the logic board.
Pull the fan away from the SSD until you can easily access the fan connector.
Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
Инструмент, используемый на этом этапе:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Cease prying when the removal tool makes contact with the opening in the rear case.
Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
Use tweezers or your fingers to pull the clip away from the AC-in socket, and remove it from the Mac mini.
To free the power supply from the case, grab the AC-In connector, which acts like a latch.
Rotate the AC-In connector 90 degrees counter-clockwise.
Slide the power supply out of the mini, minding any cables that may get caught.
3 участников успешно повторили данное руководство.
