Mac mini Mid 2010 Power Supply Replacement
Выберете то, что вам нужно
  1. Mac mini Mid 2010 Power Supply Replacement, Bottom Cover: шаг 1, изображение 1 из 2 Mac mini Mid 2010 Power Supply Replacement, Bottom Cover: шаг 1, изображение 2 из 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  2. Mac mini Mid 2010 Power Supply Replacement: шаг 2, изображение 1 из 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac mini Mid 2010 Power Supply Replacement, Fan: шаг 3, изображение 1 из 1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac mini Mid 2010 Power Supply Replacement: шаг 4, изображение 1 из 1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
  5. Mac mini Mid 2010 Power Supply Replacement: шаг 5, изображение 1 из 1
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
    • Remove the fan.
  6. Mac mini Mid 2010 Power Supply Replacement, Cowling: шаг 6, изображение 1 из 1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac mini Mid 2010 Power Supply Replacement: шаг 7, изображение 1 из 1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Mac mini Mid 2010 Power Supply Replacement, Antenna Plate: шаг 8, изображение 1 из 1
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 or T9 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
  9. Mac mini Mid 2010 Power Supply Replacement: шаг 9, изображение 1 из 2 Mac mini Mid 2010 Power Supply Replacement: шаг 9, изображение 2 из 2
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate straight away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Mac mini Mid 2010 Power Supply Replacement: шаг 10, изображение 1 из 1
    • Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
  11. Mac mini Mid 2010 Power Supply Replacement: шаг 11, изображение 1 из 1
    • Remove the antenna plate from the mini.
  12. Mac mini Mid 2010 Power Supply Replacement, Logic Board: шаг 12, изображение 1 из 1
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  13. Mac mini Mid 2010 Power Supply Replacement: шаг 13, изображение 1 из 2 Mac mini Mid 2010 Power Supply Replacement: шаг 13, изображение 2 из 2
    • Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
  14. Mac mini Mid 2010 Power Supply Replacement: шаг 14, изображение 1 из 2 Mac mini Mid 2010 Power Supply Replacement: шаг 14, изображение 2 из 2
    • Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
  15. Mac mini Mid 2010 Power Supply Replacement: шаг 15, изображение 1 из 1
    • To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
  16. Mac mini Mid 2010 Power Supply Replacement: шаг 16, изображение 1 из 1
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
  17. Mac mini Mid 2010 Power Supply Replacement: шаг 17, изображение 1 из 3 Mac mini Mid 2010 Power Supply Replacement: шаг 17, изображение 2 из 3 Mac mini Mid 2010 Power Supply Replacement: шаг 17, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Mac mini Logic Board Removal Tool
    Купить
    • To remove the logic board, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
    • If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
  18. Mac mini Mid 2010 Power Supply Replacement: шаг 18, изображение 1 из 1
    • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
  19. Mac mini Mid 2010 Power Supply Replacement: шаг 19, изображение 1 из 1
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use a pair of tweezers to disconnect the power cable from the logic board.
    • Pull the power cable connector toward the optical drive opening.
  20. Mac mini Mid 2010 Power Supply Replacement: шаг 20, изображение 1 из 1
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
  21. Mac mini Mid 2010 Power Supply Replacement, Power Supply: шаг 21, изображение 1 из 1
    • Remove the 7.9 mm T6 Torx screw securing the power supply and optical drive to the outer case.
  22. Mac mini Mid 2010 Power Supply Replacement: шаг 22, изображение 1 из 2 Mac mini Mid 2010 Power Supply Replacement: шаг 22, изображение 2 из 2
    • Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini.
  23. Mac mini Mid 2010 Power Supply Replacement: шаг 23, изображение 1 из 2 Mac mini Mid 2010 Power Supply Replacement: шаг 23, изображение 2 из 2
    • Rotate the AC-In connector 90 degrees counter-clockwise.
  24. Mac mini Mid 2010 Power Supply Replacement: шаг 24, изображение 1 из 1
    • Slide the power supply out of the mini, minding any cables that may get caught.
Заключение
21 участников успешно повторили данное руководство.
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 16
За последние 30 дней: 59
За всё время: 21,325
