Mac mini Mid 2011 AirPort/Bluetooth Board Replacement
Выберете то, что вам нужно
  1. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, Bottom Cover: шаг 1, изображение 1 из 2 Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, Bottom Cover: шаг 1, изображение 2 из 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 2, изображение 1 из 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, Fan: шаг 3, изображение 1 из 1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 4, изображение 1 из 1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
  5. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 5, изображение 1 из 3 Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 5, изображение 2 из 3 Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 5, изображение 3 из 3
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
  6. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, Cowling: шаг 6, изображение 1 из 1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 7, изображение 1 из 1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, Antenna Plate: шаг 8, изображение 1 из 1
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
    • When putting back together:
    • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
    • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
  9. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 9, изображение 1 из 2 Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 9, изображение 2 из 2
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 10, изображение 1 из 1
    • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
  11. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 11, изображение 1 из 1
    • Remove the antenna plate from the mini.
  12. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, Logic Board: шаг 12, изображение 1 из 2 Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, Logic Board: шаг 12, изображение 2 из 2
    • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
  13. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 13, изображение 1 из 1
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
    • Make sure to pry up from beneath the wires and not underneath the socket.
  14. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 14, изображение 1 из 1
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case.
    • Remove the Mac mini Logic Board Removal tool.
  15. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 16, изображение 1 из 1
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use your fingers to disconnect the DC-In cable from the logic board.
    • Pull the power cable connector toward the front side of the mini.
  16. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 17, изображение 1 из 1
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
  17. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, Speaker: шаг 18, изображение 1 из 1
    • Remove the following two screws securing the speaker to the logic board assembly:
    • One 3.5 mm T6 Torx screw
    • One 3.7 mm T6 Torx screw
  18. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 19, изображение 1 из 2 Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 19, изображение 2 из 2
    • Lift but do not remove the speaker assembly, as it still remains connected to the logic board via the speaker connector.
    • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
    • Lift and remove the speaker away from the logic board.
  19. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: шаг 20, изображение 1 из 2 Mac mini Mid 2011 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: шаг 20, изображение 2 из 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth board.
  20. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 21, изображение 1 из 1
    • Use your spudger to help disconnect the AirPort/Bluetooth ribbon cable from its socket on the AirPort/Bluetooth board.
  21. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 22, изображение 1 из 1
    • Remove the two 2.6 mm T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
  22. Mac mini Mid 2011 AirPort/Bluetooth Board Replacement: шаг 23, изображение 1 из 1
    • Remove the AirPort/Bluetooth board from the logic board.
Заключение
6 участников успешно повторили данное руководство.
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 57
За всё время: 20,245
