Введение
Remove the top housing to access your mini's internals.
Выберете то, что вам нужно
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
Patience is your best friend.
Do not insert “jimmy in too far. Marking a line from tip upwards on the tool will prevent too far insertion, possibly breaking tabs or damaging internal components.
To prevent the cover closing back up, small strips of matchbook cover (os equivalent) can be inserted about half inch hold prevent closure.
Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
Flip the Mac mini back over and lift the top housing off of the lower housing.
47 участников успешно повторили данное руководство.
2 Комментариев
Does this work to remove a disc
That's part of the process. After that, you will probably need to disassemble the optical drive.
Skylar -
A spackle knife makes these steps go much faster.
jouniseppanen - Ответить
A double sided letter opener or a thin non-serrated butter knife will suffice.
To prenent cosmetic blemishes, place a matchbook cover or similar thin cardboard on the outer perimeter under the “jimmy”.
Mike - Ответить
