Введение
Use this guide to replace your AirPort/Bluetooth board in the MacBook Air 11" Early 2015.
Выберете то, что вам нужно
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way of the card.
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
Slightly lift the free end of the AirPort/Bluetooth board and pull it straight out of its socket on the logic board.
7 участников успешно повторили данное руководство.
Один комментарий
I did this with an early 2015 MacBook pro. I'm having trouble getting it to recognize all my devices. Anyone have this trouble? Is there a driver or something on the software end that I need to deal with?
Thanks
