MacBook Air 11" Early 2015 Display Replacement
Выберете то, что вам нужно
  1. MacBook Air 11" Early 2015 Display Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Купить
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2015 Display Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 Display Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement, Battery Connector: шаг 3, изображение 2 из 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2015 Display Replacement, I/O Board Cable: шаг 4, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement, I/O Board Cable: шаг 4, изображение 2 из 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2015 Display Replacement: шаг 5, изображение 1 из 1
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Early 2015 Display Replacement, Fan: шаг 6, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement, Fan: шаг 6, изображение 2 из 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Early 2015 Display Replacement: шаг 7, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement: шаг 7, изображение 2 из 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Early 2015 Display Replacement: шаг 8, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement: шаг 8, изображение 2 из 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Early 2015 Display Replacement: шаг 9, изображение 1 из 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Early 2015 Display Replacement: шаг 10, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 10, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 10, изображение 3 из 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Early 2015 Display Replacement, Logic Board Assembly: шаг 11, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement, Logic Board Assembly: шаг 11, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement, Logic Board Assembly: шаг 11, изображение 3 из 3
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
  12. MacBook Air 11" Early 2015 Display Replacement: шаг 12, изображение 1 из 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  13. MacBook Air 11" Early 2015 Display Replacement: шаг 13, изображение 1 из 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  14. MacBook Air 11" Early 2015 Display Replacement: шаг 14, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement: шаг 14, изображение 2 из 2
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  15. MacBook Air 11" Early 2015 Display Replacement: шаг 15, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 15, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 15, изображение 3 из 3
    • Use the tip of a spudger to de-route the antenna cables from their notches in the logic board.
  16. MacBook Air 11" Early 2015 Display Replacement: шаг 16, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 16, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 16, изображение 3 из 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, gently pull the display data cable out of its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  17. MacBook Air 11" Early 2015 Display Replacement: шаг 17, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 17, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 17, изображение 3 из 3
    • Use the tip of a spudger to pry under the speaker cable connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  18. MacBook Air 11" Early 2015 Display Replacement: шаг 18, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 18, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 18, изображение 3 из 3
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  19. MacBook Air 11" Early 2015 Display Replacement: шаг 19, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 19, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 19, изображение 3 из 3
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  20. MacBook Air 11" Early 2015 Display Replacement: шаг 20, изображение 1 из 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  21. MacBook Air 11" Early 2015 Display Replacement: шаг 21, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 21, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 21, изображение 3 из 3
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  22. MacBook Air 11" Early 2015 Display Replacement: шаг 22, изображение 1 из 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
    • In some models these are 3.1 mm T5 Torx screws.
  23. MacBook Air 11" Early 2015 Display Replacement: шаг 23, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 23, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 23, изображение 3 из 3
    • Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
    • When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
  24. MacBook Air 11" Early 2015 Display Replacement, I/O Board: шаг 24, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement, I/O Board: шаг 24, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement, I/O Board: шаг 24, изображение 3 из 3
    • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
    • Remove the gasket from the corner nearest display cable connector.
  25. MacBook Air 11" Early 2015 Display Replacement: шаг 25, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement: шаг 25, изображение 2 из 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  26. MacBook Air 11" Early 2015 Display Replacement: шаг 26, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 26, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 26, изображение 3 из 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
  27. MacBook Air 11" Early 2015 Display Replacement: шаг 27, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 27, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 27, изображение 3 из 3
    • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
  28. MacBook Air 11" Early 2015 Display Replacement: шаг 28, изображение 1 из 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  29. MacBook Air 11" Early 2015 Display Replacement: шаг 29, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 29, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement: шаг 29, изображение 3 из 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
  30. MacBook Air 11" Early 2015 Display Replacement, Display Assembly: шаг 30, изображение 1 из 3 MacBook Air 11" Early 2015 Display Replacement, Display Assembly: шаг 30, изображение 2 из 3 MacBook Air 11" Early 2015 Display Replacement, Display Assembly: шаг 30, изображение 3 из 3
    • Peel up the six cable loops securing the antenna cables to the upper case.
    • In some models there are seven cable loops.
    • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
    • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
    • Repeat this for each retaining loop until the antenna cables are free from the upper case.
  31. MacBook Air 11" Early 2015 Display Replacement: шаг 31, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement: шаг 31, изображение 2 из 2
    • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
  32. MacBook Air 11" Early 2015 Display Replacement: шаг 32, изображение 1 из 1
    • Open the display until it is perpendicular to the upper case and place it on a table as shown.
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
  33. MacBook Air 11" Early 2015 Display Replacement: шаг 33, изображение 1 из 1
    • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
  34. MacBook Air 11" Early 2015 Display Replacement: шаг 34, изображение 1 из 2 MacBook Air 11" Early 2015 Display Replacement: шаг 34, изображение 2 из 2
    • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
    • Once the two display hinges have cleared the upper case, remove the display.
Заключение
25 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
465 777 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
3 Комментариев
I was able to bring back my MacBook Air for just the cost of the parts after the Apple Store quoted the repair at costing almost as much as the device itself! My Ifixit kit had everything I needed to do the job with ease.
Michael Gorman - Ответить
was able to ebay a new screen and followed this guide to replace my macbook air. Thanks !
Jason Kwong - Ответить
This is an amazing guide. I was able to replace the screen in an hour. Noticed that in 13” models, I believe that this is a bit easier. Apple made it not super easy to replace the screen on this one, since we literally have to take everything apart to replace the display.
The tricky part was the little loops in which the bluetooth cables go through - I used a pair of tweezers to be careful not to remove them off and put the new cables back. Too bad Apple use a mix of so many different screws - I put each set of screws on a paper page and wrote where the screws go.
Everything else was fairly easy. Super important to have the right tools though.
Thanks Sam for your work, I saved $400 thanks to this guide.
Percival H. - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 35
За последние 30 дней: 145
За всё время: 25,763
