MacBook Air 11" Early 2015 I/O Board Replacement
Выберете то, что вам нужно
  1. MacBook Air 11" Early 2015 I/O Board Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
    Спросите у FixBot
    Добавить комментарий
  2. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    Спросите у FixBot
  3. MacBook Air 11" Early 2015 I/O Board Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement, Battery Connector: шаг 3, изображение 2 из 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
    Спросите у FixBot
  4. MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board Cable: шаг 4, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board Cable: шаг 4, изображение 2 из 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
    Спросите у FixBot
  5. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 5, изображение 1 из 1
    • Lift and remove the I/O board cable.
    Спросите у FixBot
  6. MacBook Air 11" Early 2015 I/O Board Replacement, Fan: шаг 6, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement, Fan: шаг 6, изображение 2 из 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
    Спросите у FixBot
  7. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 7, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 7, изображение 2 из 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
    Спросите у FixBot
  8. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 8, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 8, изображение 2 из 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    Спросите у FixBot
  9. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 9, изображение 1 из 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
    Спросите у FixBot
  10. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 10, изображение 1 из 3 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 10, изображение 2 из 3 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 10, изображение 3 из 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
    Спросите у FixBot
  11. MacBook Air 11" Early 2015 I/O Board Replacement, Battery: шаг 11, изображение 1 из 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
    Спросите у FixBot
  12. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 12, изображение 1 из 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    Спросите у FixBot
  13. MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board: шаг 13, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board: шаг 13, изображение 2 из 2
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
    Спросите у FixBot
  14. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 14, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 14, изображение 2 из 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
    Спросите у FixBot
  15. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 15, изображение 1 из 3 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 15, изображение 2 из 3 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 15, изображение 3 из 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
    Спросите у FixBot
  16. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 16, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 16, изображение 2 из 2
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
    Спросите у FixBot
  17. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 17, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 17, изображение 2 из 2
    • De-route the cable from its notch in the I/O board.
    Спросите у FixBot
  18. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 18, изображение 1 из 2 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 18, изображение 2 из 2
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
    Спросите у FixBot
  19. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 19, изображение 1 из 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • In some models this is a 3.1 mm T5 Torx screw.
    Спросите у FixBot
  20. MacBook Air 11" Early 2015 I/O Board Replacement: шаг 20, изображение 1 из 3 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 20, изображение 2 из 3 MacBook Air 11" Early 2015 I/O Board Replacement: шаг 20, изображение 3 из 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
    Спросите у FixBot
Заключение
11 человек успешно провели ремонт по этому руководству.
Sam Goldheart
Участник с: 10/18/12
477 637 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
122 членов
Автор 27 498 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 21
За последние 30 дней: 87
За всё время: 8,048
