Введение
Internal Prereq for battery removal when fan is out.
Запчасти
No parts specified.
  1. Remove the following five screws securing the battery to the upper case:
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  2. Do not touch or squeeze the six lithium polymer cells when handling the battery.
    • Do not touch or squeeze the six lithium polymer cells when handling the battery.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Заключение
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 270
