MacBook Air 11" Mid 2012 I/O Board Cable Replacement
Выберете то, что вам нужно
  1. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Купить
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: шаг 3, изображение 1 из 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: шаг 3, изображение 2 из 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: шаг 4, изображение 1 из 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: шаг 4, изображение 2 из 2
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: шаг 5, изображение 1 из 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement: шаг 5, изображение 2 из 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
Заключение
3 участников успешно повторили данное руководство.
Andrew Optimus Goldheart
Участник с: 10/17/09
502 855 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
Один комментарий
You only show the basic part of the removal. You do not show how to actually remove that board. You should have shown more steps.
Steven Pierce - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 2,835
