MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement
Выберете то, что вам нужно
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  1. MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement, Battery Connector: шаг 3, изображение 2 из 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  3. MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: шаг 4, изображение 1 из 3 MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: шаг 4, изображение 2 из 3 MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: шаг 4, изображение 3 из 3
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way of the card.
  4. MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement: шаг 5, изображение 1 из 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  5. MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement: шаг 6, изображение 1 из 3 MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement: шаг 6, изображение 2 из 3 MacBook Air 11" Mid 2013 AirPort/Bluetooth Board Replacement: шаг 6, изображение 3 из 3
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it straight out of its socket on the logic board.
    • To avoid damaging the socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
Заключение
12 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
463 313 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
140 членов
Автор 15 195 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 33
За всё время: 6,144
