MacBook Air 11" Mid 2013 I/O Board Replacement
Выберете то, что вам нужно
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  1. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 11" Mid 2013 I/O Board Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement, Battery Connector: шаг 3, изображение 2 из 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  3. MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board Cable: шаг 4, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board Cable: шаг 4, изображение 2 из 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  4. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 5, изображение 1 из 1
    • Lift and remove the I/O board cable.
  5. MacBook Air 11" Mid 2013 I/O Board Replacement, Fan: шаг 6, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement, Fan: шаг 6, изображение 2 из 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  6. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 7, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 7, изображение 2 из 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  7. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 8, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 8, изображение 2 из 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  8. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 9, изображение 1 из 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  9. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 10, изображение 1 из 3 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 10, изображение 2 из 3 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 10, изображение 3 из 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  10. MacBook Air 11" Mid 2013 I/O Board Replacement, Battery: шаг 11, изображение 1 из 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  11. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 12, изображение 1 из 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  12. MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: шаг 13, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: шаг 13, изображение 2 из 2
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  13. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 14, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 14, изображение 2 из 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  14. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 15, изображение 1 из 3 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 15, изображение 2 из 3 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 15, изображение 3 из 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  15. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 16, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 16, изображение 2 из 2
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
  16. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 17, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 17, изображение 2 из 2
    • De-route the cable from its notch in the I/O board.
  17. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 18, изображение 1 из 2 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 18, изображение 2 из 2
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  18. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 19, изображение 1 из 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • In some models this is a 3.1 mm T5 Torx screw.
  19. MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 20, изображение 1 из 3 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 20, изображение 2 из 3 MacBook Air 11" Mid 2013 I/O Board Replacement: шаг 20, изображение 3 из 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Заключение
21 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
463 313 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
140 членов
Автор 15 195 руководств
Один комментарий
Great tutorial. I may do this for sure. I get no audio and no microphone on my MacBook air. I took it to Apple and they told me it was hardware and not software. In Settins in Audio, there is no Audio Ouput available and No built in Mic available. Would you imagine this might be what is wrong with my Air?
Jon Bonci - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 28
За всё время: 8,339
