Введение
Use this guide to replace the fan in a 2018 MacBook Air.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
Use a T4 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
Remove the cable bracket.
Use the flat end of a spudger to pry the audio board connector straight up and disconnect it.
Use the flat end of a spudger to pry the Touch ID sensor connector straight up and disconnect it.
Remove the following screws:
Two 4.3 mm, T5 Torx screws
One 2.4 mm, T4 Torx screw
Slide the flat end of a spudger underneath the Touch ID sensor cable to slice through the adhesive securing it to the audio board.
Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
Slide the fan cable out of the ZIF connector.
Slide an opening pick under the audio board cable to slice through the adhesive securing it to the fan.
Use a T5 Torx driver to remove the three 2.7 mm screws securing the fan.
