Введение
Use this guide to replace the I/O board, including the headphone jack, USB port, and MagSafe 2 port, in your MacBook Air 13" Early 2015.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
Remove the I/O board cable.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following three screws securing the fan to the upper case:
One 5.2 mm T5 Torx screw
One 3.3 mm T5 Torx screw
One 4.4 mm T5 Torx screw with a short head
Lift the fan from the I/O board side and pull it free from the upper case.
Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
Remove the single 4.1 mm T5 Torx screw securing the I/O board to the upper case.
Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
Lift the I/O board from the logic board side and pull it free from the upper case.
Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
45 участников успешно повторили данное руководство.
15 Комментариев
Ich habe ein Macbook Air 2015 early. Das Ladekabel leuchtet nicht und die Batterie wird nicht geladen, ohne Batterie läuft das Macbook und auch solange die Batterie geladen ist läuft es einwandfrei auch ohne Ladekabel. Woher bekomme ich das I-O board und denkt ihr es liegt am I-O board oder eher irgendwo auf dem Mainboard das Problem?
Man kann das I/O-board bei ebay finden, kostet nicht viel, der Austausch ist ja oben beschrieben, man muss da sehr vorsichtig vorgehen, zB das dünne, kurze Flexkabel ganz am Schluss.
Jamba -
I successfully fixed my Macbook Air early 2015. Power cord LED indicator was dark and the battery was not charging. This was because my power supply blew up while stuck within the couch and went dangerously hot. Power supply died as the IO Board too.
Replacing the IO Board fixed my Macbook.
Hi . I replaced my IO board because the power socket was burned. With the new board the Macbook air mid 2011 was running very slow. Changed back to the old one and computer was running as normal. Any Ideas why the new IO board was slowing the computer down. The USB port in the new board was also not working.
