Введение
Use this guide to replace a damaged MacBook Air 13" Early 2015 lower case.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:P5 Pentalobe Screwdriver Retina MacBook Pro and Air
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
16 участников успешно повторили данное руководство.
Один комментарий
Not sure how this is considered “Moderate” difficulty… It doesn’t get any more simple than this, does it?
