Введение
Use this guide to replace a faulty battery in your MacBook Air 13" Early 2017.
Note: If there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Remove the following five screws securing the battery to the upper case:
Three 6.9 mm T5 Torx screws
Two 3.0 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
41 участников успешно повторили данное руководство.
Комментариев: 8
how do I find out if my macbook air is early 2017 or late 2017? I want to make sure I buy the right battery replacement.
If you go here you can enter your serial number and then it will tell you
Vá na maçã, click em "Sobre este Mac", vá na aba "Recursos", vá embaixo em "Recursos do Mac" - Especificações.
Vai abrir uma pagina na internet com as especificações do seu Mac.
Esses passos é para o mac 2015, talvez não seja do seu mac, mas poderia tentar.
