Введение
Use this guide to replace a damaged MacBook Air 13" Early 2017 lower case.
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
Еще один человек закончил это руководство.
