MacBook Air 13" Early 2017 Right Speaker Replacement
Выберете то, что вам нужно
  1. MacBook Air 13" Early 2017 Right Speaker Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2017 Right Speaker Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2017 Right Speaker Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 13" Early 2017 Right Speaker Replacement, Battery Connector: шаг 3, изображение 2 из 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2017 Right Speaker Replacement, Battery: шаг 4, изображение 1 из 1
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  5. MacBook Air 13" Early 2017 Right Speaker Replacement: шаг 5, изображение 1 из 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  6. MacBook Air 13" Early 2017 Right Speaker Replacement: шаг 6, изображение 1 из 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  7. MacBook Air 13" Early 2017 Right Speaker Replacement, Right Speaker: шаг 7, изображение 1 из 1
    • Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
    • Pry up from beneath the wires.
  8. MacBook Air 13" Early 2017 Right Speaker Replacement: шаг 8, изображение 1 из 3 MacBook Air 13" Early 2017 Right Speaker Replacement: шаг 8, изображение 2 из 3 MacBook Air 13" Early 2017 Right Speaker Replacement: шаг 8, изображение 3 из 3
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Remove the right speaker from the upper case.
Заключение
2 человек успешно провели ремонт по этому руководству.
Adam O'Camb
Участник с: 04/11/15
209 084 Репутация
Автор 416 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 12
За последние 30 дней: 82
За всё время: 2,098
