MacBook Air 13" Late 2020 Antenna Bar Replacement
Выберете то, что вам нужно
    1. MacBook Air 13" Late 2020 Antenna Bar Replacement, Remove the screws securing the lower case: шаг 1, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Magnetic Project Mat
      $19.95
      • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
      • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
      • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
      • Use a P5 driver to remove the following screws:
      • Two 7.9 mm screws
      • Two 7.3 mm screws
      • Six 2.6 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Air 13" Late 2020 Antenna Bar Replacement, Remove the lower case: шаг 2, изображение 1 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement, Remove the lower case: шаг 2, изображение 2 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement, Remove the lower case: шаг 2, изображение 3 из 3
      • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
      Спросите у FixBot
    1. MacBook Air 13" Late 2020 Antenna Bar Replacement, Disconnect the battery: шаг 3, изображение 1 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement, Disconnect the battery: шаг 3, изображение 2 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement, Disconnect the battery: шаг 3, изображение 3 из 3
      • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
      • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
      • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
      • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
      • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
      Спросите у FixBot
    1. MacBook Air 13" Late 2020 Antenna Bar Replacement, Disconnect the antenna cables: шаг 4, изображение 1 из 1
      • Use a T3 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
      • If your T3 bit feels a bit too loose, you may need to use a T4.
      Спросите у FixBot
    2. MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 5, изображение 1 из 1
      • Remove the antenna cable cover.
      Спросите у FixBot
    3. MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 6, изображение 1 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 6, изображение 2 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 6, изображение 3 из 3
      • Use a pair of tweezers to grip the antenna connector close to its base.
      • Pull straight up to disconnect the cable.
      • Repeat for the second antenna cable.
      • During reassembly, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets.
      Спросите у FixBot
    4. MacBook Air 13" Late 2020 Antenna Bar Replacement, Disconnect the display cable: шаг 7, изображение 1 из 1
      • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
      Спросите у FixBot
    5. MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 8, изображение 1 из 1
      • Remove the display cable connector cover.
      Спросите у FixBot
    6. MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 9, изображение 1 из 2 MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 9, изображение 2 из 2
      • Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Спросите у FixBot
    7. MacBook Air 13" Late 2020 Antenna Bar Replacement, Remove the antenna bar screws: шаг 10, изображение 1 из 1
      • Use a T5 Torx driver to remove the six screws securing the antenna bar:
      • Four 7.4 mm silver screws
      • Two 4.7 mm black screws
      Спросите у FixBot
    8. MacBook Air 13" Late 2020 Antenna Bar Replacement, Remove the antenna bar: шаг 11, изображение 1 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement, Remove the antenna bar: шаг 11, изображение 2 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement, Remove the antenna bar: шаг 11, изображение 3 из 3
      • Insert the pointed end of a spudger into the gap between the antenna bar and display hinge.
      • Pivot the spudger against the hinge to pry up the end of the antenna bar.
      • Note that the antenna bar may be lightly adhered to the frame.
      • Repeat for the other end of the antenna bar.
      Спросите у FixBot
    9. MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 12, изображение 1 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 12, изображение 2 из 3 MacBook Air 13" Late 2020 Antenna Bar Replacement: шаг 12, изображение 3 из 3
      • Use your fingers to pry the antenna bar straight up and away from the case.
      • The antenna bar is secured with some adhesive and may require some force to dislodge.
      • Thread the antenna board through the opening in the middle of the antenna bar.
      • Be careful to not put any strain on the antenna bar's ribbon cables.
      • Remove the antenna bar.
      Спросите у FixBot
Заключение
Once you've completed your repair, your laptop may not power back on until connected to power.
11 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
170 870 Репутация
Автор 442 руководств
Команда
iFixit Участник iFixit
Staff
122 членов
Автор 86 241 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 22
За последние 7 дней: 96
За последние 30 дней: 383
За всё время: 21,333
