MacBook Air 13" Late 2020 Audio Board Replacement
Выберете то, что вам нужно
  1. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the screws securing the lower case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    Спросите у FixBot
    Добавить комментарий
  2. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: шаг 2, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: шаг 2, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: шаг 2, изображение 3 из 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    Спросите у FixBot
  3. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: шаг 3, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: шаг 3, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: шаг 3, изображение 3 из 3
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
    Спросите у FixBot
  4. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board connector cover: шаг 4, изображение 1 из 1
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
    Спросите у FixBot
  5. MacBook Air 13" Late 2020 Audio Board Replacement: шаг 5, изображение 1 из 1
    • Remove the audio board connector cover.
    Спросите у FixBot
  6. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: шаг 6, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: шаг 6, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: шаг 6, изображение 3 из 3
    • Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
    Спросите у FixBot
  7. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: шаг 7, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: шаг 7, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: шаг 7, изображение 3 из 3
    • Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
    • Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
    • The Touch ID cable is secured to the audio board with some light adhesive.
    Спросите у FixBot
  8. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the audio board cable: шаг 8, изображение 1 из 2 MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the audio board cable: шаг 8, изображение 2 из 2
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Спросите у FixBot
  9. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board screws: шаг 9, изображение 1 из 1
    • Remove the three screws securing the audio board:
    • Two 4.8 mm T5 Torx screws
    • One 2.5 mm T3 Torx screw
    Спросите у FixBot
  10. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: шаг 10, изображение 1 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: шаг 10, изображение 2 из 3 MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: шаг 10, изображение 3 из 3
    • Use a spudger to pry the audio board out of the upper case until you can grip it with your fingers.
    • Remove the audio board.
    Спросите у FixBot
Заключение
Once you've completed your repair, your laptop may not power back on until connected to power.
12 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
167 268 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 27 624 руководств
3 Комментарии к руководству
Ich hatte einen Wasserschaden und seit diesem funktionieren die Lautsprecher nicht mehr. Es kommt kein Ton raus aus beiden Seiten. Zunächst hörte ich noch das Neustartgeräusch. Nachdem ich aber den dann Laptop auseinandergebaut, getrocknet und wieder zusammengebaut hatte kein Ton mehr. Die Lautsprecher selbst wurde allerdings nicht wirklich nass. Kann die Audioplatine hier die Ursache sein und ein Austausch helfen? Die anderen Funktionen, wie Touch-ID, die über die Audioplatine laufen, funktionieren allerdings noch. Gibt es sonst noch ein einzelnes Bauteil oder Kabel, welches dafür verantwortlich sein könnte?
Ich gehe davon aus, dass die Lautsprecher an sich noch intakt sind.
Richard - Ответить Поделиться
Richard,
Entschuldigen Sie zunächst mein schlechtes Deutsch. Es lohnt sich wahrscheinlich, die Audioplatine auszubauen und anschließend zu reinigen. Verwenden Sie zum Reinigen der Anschlüsse >90% Isopropylalkohol und eine weiche Bürste wie eine Zahnbürste. Auf sichtbare Korrosion prüfen. Konzentrierte sich der Wasserschaden auf die Nähe der Audioplatine? Ich glaube nicht, dass Wasser den Lautsprechern Schaden zufügen würde, es sei denn, sie würden in Wasser getaucht, oder dass das Wasser speziell ihren Stecker beschädigt hätte. Viel Glück bei deiner Reparatur. Ich bin gespannt, ob Sie das Problem lösen.
Carsten Frauenheim - Ответить Поделиться
my mac can using touch id, built-in speaker is normal , but when i put headphone in the 3.5mmjack , mac's sound manager cant show it, is the sound module broken?
楚羽 柳 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 14
За последние 7 дней: 75
За последние 30 дней: 281
За всё время: 16,338
