MacBook Air 13" Late 2020 Touch ID Sensor Replacement
Выберете то, что вам нужно
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  1. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the lower case: шаг 2, изображение 1 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the lower case: шаг 2, изображение 2 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the lower case: шаг 2, изображение 3 из 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  2. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the battery: шаг 3, изображение 1 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the battery: шаг 3, изображение 2 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the battery: шаг 3, изображение 3 из 3
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
  3. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board connector cover: шаг 4, изображение 1 из 1
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  4. MacBook Air 13" Late 2020 Touch ID Sensor Replacement: шаг 5, изображение 1 из 1
    • Remove the audio board connector cover.
  5. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the speaker: шаг 6, изображение 1 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the speaker: шаг 6, изображение 2 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the speaker: шаг 6, изображение 3 из 3
    • Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
  6. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the Touch ID cable: шаг 7, изображение 1 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the Touch ID cable: шаг 7, изображение 2 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the Touch ID cable: шаг 7, изображение 3 из 3
    • Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
    • Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
    • The Touch ID cable is secured to the audio board with some light adhesive.
  7. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the audio board cable: шаг 8, изображение 1 из 2 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the audio board cable: шаг 8, изображение 2 из 2
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board screws: шаг 9, изображение 1 из 1
    • Remove the three screws securing the audio board:
    • Two 4.8 mm T5 Torx screws
    • One 2.5 mm T3 Torx screw
  9. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board: шаг 10, изображение 1 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board: шаг 10, изображение 2 из 3 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board: шаг 10, изображение 3 из 3
    • Use a spudger to pry the audio board out of the upper case until you can grip it with your fingers.
    • Remove the audio board.
  10. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the Touch ID sensor screws: шаг 11, изображение 1 из 2 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the Touch ID sensor screws: шаг 11, изображение 2 из 2
    • Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
    • During reassembly, if you want your Touch ID button to be straight, don't tighten down the six screws until you adjust its position on the keyboard.
  11. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the Touch ID bracket: шаг 12, изображение 1 из 1
    • Remove the Touch ID sensor bracket.
  12. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the Touch ID sensor: шаг 13, изображение 1 из 1
    • Turn the MacBook right-side up and open the display.
    • Remove the Touch ID sensor.
Заключение
4 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
86 743 Репутация
Автор 332 руководств
Команда
iFixit Участник iFixit
Community
138 членов
Автор 17 042 руководств
2 Комментариев
Servus! Angenommen, der Stecker hat sich beim Sturz nur gelöst und man steckt ihn wieder drauf. Kann man dann Touch ID wieder nutzen? Ode muss man immer das Logicboard tauschen, sobald der Stecker abgelöst wurde? Grüße
David Braun - Ответить
Is it safe to remove the power button without going through the back? My touch sensor isn't working and I think something's blocking it. I simply want to remove the power key to clean... and put it right back in.
Kemi Burgen - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 160
За последние 30 дней: 712
За всё время: 9,835
