MacBook Air 13" Mid 2012 I/O Board Cable Replacement
Выберете то, что вам нужно
  1. MacBook Air 13" Mid 2012 I/O Board Cable Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Купить
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2012 I/O Board Cable Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2012 I/O Board Cable Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 13" Mid 2012 I/O Board Cable Replacement, Battery Connector: шаг 3, изображение 2 из 2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  4. MacBook Air 13" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: шаг 4, изображение 1 из 1
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 13" Mid 2012 I/O Board Cable Replacement: шаг 5, изображение 1 из 1
    • Carefully peel the I/O board cable from the top of the fan.
  6. MacBook Air 13" Mid 2012 I/O Board Cable Replacement: шаг 6, изображение 1 из 2 MacBook Air 13" Mid 2012 I/O Board Cable Replacement: шаг 6, изображение 2 из 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
Заключение
10 участников успешно повторили данное руководство.
Andrew Optimus Goldheart
Участник с: 10/17/09
502 810 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 22
За всё время: 6,137
