ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’Ρ‹Π±Π΅Ρ€Π΅Ρ‚Π΅ Ρ‚ΠΎ, Ρ‡Ρ‚ΠΎ Π²Π°ΠΌ Π½ΡƒΠΆΠ½ΠΎ
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Mid 2013 I/O Board Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Mid 2013 I/O Board Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 13" Mid 2013 I/O Board Replacement, Battery Connector: step 3, image 2 of 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  3. MacBook Air 13" Mid 2013 I/O Board Replacement, I/O Board Cable: step 4, image 1 of 1
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
  4. MacBook Air 13" Mid 2013 I/O Board Replacement: step 5, image 1 of 1
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
  5. MacBook Air 13" Mid 2013 I/O Board Replacement: step 6, image 1 of 2 MacBook Air 13" Mid 2013 I/O Board Replacement: step 6, image 2 of 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  6. MacBook Air 13" Mid 2013 I/O Board Replacement, Fan: step 7, image 1 of 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  7. MacBook Air 13" Mid 2013 I/O Board Replacement: step 8, image 1 of 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
  8. MacBook Air 13" Mid 2013 I/O Board Replacement: step 9, image 1 of 1
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
  9. MacBook Air 13" Mid 2013 I/O Board Replacement: step 10, image 1 of 2 MacBook Air 13" Mid 2013 I/O Board Replacement: step 10, image 2 of 2
    • Lift the fan from the I/O board side and pull it free from the upper case.
    • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
  10. MacBook Air 13" Mid 2013 I/O Board Replacement, I/O Board: step 11, image 1 of 1
    • Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
  11. MacBook Air 13" Mid 2013 I/O Board Replacement: step 12, image 1 of 2 MacBook Air 13" Mid 2013 I/O Board Replacement: step 12, image 2 of 2
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  12. MacBook Air 13" Mid 2013 I/O Board Replacement: step 13, image 1 of 2 MacBook Air 13" Mid 2013 I/O Board Replacement: step 13, image 2 of 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
  13. MacBook Air 13" Mid 2013 I/O Board Replacement: step 14, image 1 of 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  14. MacBook Air 13" Mid 2013 I/O Board Replacement: step 15, image 1 of 2 MacBook Air 13" Mid 2013 I/O Board Replacement: step 15, image 2 of 2
    • Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
  15. MacBook Air 13" Mid 2013 I/O Board Replacement: step 16, image 1 of 1
    • Lift the I/O board from the logic board side and pull it free from the upper case.
    • Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
Π—Π°ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠ΅
45 участников ΡƒΡΠΏΠ΅ΡˆΠ½ΠΎ ΠΏΠΎΠ²Ρ‚ΠΎΡ€ΠΈΠ»ΠΈ Π΄Π°Π½Π½ΠΎΠ΅ руководство.
Walter Galan
682Β 731 РСпутация
Автор 1Β 203 руководств
7 Comments
How can I tell if its my I/O board that is damaged? I cannot hear sound from Aux port or from the speakers on my macbook. Laptop still charges fine though.
Ralphy Sierra - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Check to see if your USB port on that side works. That was how I know mine was bad.
craig - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
If light on magsafe doesn't turn on, is it safe to say the io board needs to be replaced?
Jon Lewin - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 2
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 29
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 119
Π—Π° всё врСмя: 28,182
