Введение
Use this guide to replace the right speaker in a 2019 MacBook Air. This is the speaker on the headphone jack side of the case.
  1. Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
  3. Peel back the tape covering the battery connector enough to reveal the connector underneath.
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board. Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers. Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the speaker. Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
    • Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • If the adhesive strip breaks, leave it in and proceed to the next step.
  6. Slide the tip of a spudger underneath the right speaker cable and pry straight up to disconnect the speaker. Slide the tip of a spudger underneath the right speaker cable and pry straight up to disconnect the speaker.
    • Slide the tip of a spudger underneath the right speaker cable and pry straight up to disconnect the speaker.
  7. Use tweezers to lift the adhesive pull tab at the top of the right speaker enough that you can grab it with your fingers. Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the speaker. Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • Use tweezers to lift the adhesive pull tab at the top of the right speaker enough that you can grab it with your fingers.
    • If the adhesive strip breaks, or if the first adhesive strip broke, use a heated iOpener or heat gun to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  8. Lift the right speaker straight up from the bottom and remove it.
    • Lift the right speaker straight up from the bottom and remove it.
Заключение
Еще один человек закончил это руководство.
Adam O'Camb
Участник с: 11.04.2015
149 792 Репутация
Автор 418 руководств
Команда
iFixit Участник iFixit
Community
138 членов
Автор 15 634 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 49
За всё время: 816
