Введение
Use this guide to replace the Touch ID sensor in a 2019 MacBook Air.
Note that Touch ID will not function after replacing the Touch ID sensor. The MacBook’s original Touch ID sensor is uniquely paired to the T2 chip on the logic board at the factory—and without Apple’s proprietary calibration process, even a genuine replacement Touch ID sensor from another MacBook Air won’t work.
If you replace the Touch ID sensor, you must install a paired logic board to retain Touch ID functionality.
Выберете то, что вам нужно
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
Use a T4 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
Remove the cable bracket.
Use the flat end of a spudger to pry the audio board connector straight up and disconnect it.
Use the flat end of a spudger to pry the Touch ID sensor connector straight up and disconnect it.
Remove the following screws:
Two 4.3 mm, T5 Torx screws
One 2.4 mm, T4 Torx screw
Slide the flat end of a spudger underneath the Touch ID sensor cable to slice through the adhesive securing it to the audio board.
Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
Remove the Touch ID bracket.
Turn the MacBook right-side up and open the display.
Lift the Touch ID sensor sensor out of its recess and remove it.
4 участников успешно повторили данное руководство.
One Comment
Hold on so you can replace the touch id but you wont be able to use it? lol kind of redundant if you ask me.
