Введение
Don't pay Apple to replace your worn out battery. Do it yourself!
Выберете то, что вам нужно
Видеообзор
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Disconnect the battery connector by pulling it straight out of its socket.
Remove the following nine screws securing the battery to the Air:
Four 2.9 mm Phillips.
Four 3.8 mm Phillips.
One 7.2 mm Phillips.
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
118 человек успешно провели ремонт по этому руководству.
12 Комментарии к руководству
This doesn't make sense. The battery cost $110, plus shipping, which will come out to about $130, with next day shipping. Apple does it for $129, and will do it same day with an appointment. I know some people will do it for fun, but if you're trying to save money, I have to roll with Apple on this one.
I ordered a replacement battery for $75 (shipping included) and 3 days later the switch is done (thanks for this easy guide!). Now, my wife's MBA is free from power cord again! It is a no brainer!
I have bought the This replacment a1245 battey - A1237 and A1304 Battery
thanks for the install guide
