MacBook Air Models A1237 and A1304 Battery Replacement
Выберете то, что вам нужно
Видео обзор
  1. MacBook Air Models A1237 and A1304 Battery Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 Battery Replacement: шаг 2, изображение 1 из 2 MacBook Air Models A1237 and A1304 Battery Replacement: шаг 2, изображение 2 из 2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 Battery Replacement, Battery: шаг 3, изображение 1 из 1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 Battery Replacement: шаг 5, изображение 1 из 1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Заключение
116 участников успешно повторили данное руководство.
12 Комментариев
This doesn't make sense. The battery cost $110, plus shipping, which will come out to about $130, with next day shipping. Apple does it for $129, and will do it same day with an appointment. I know some people will do it for fun, but if you're trying to save money, I have to roll with Apple on this one.
http://www.apple.com/support/macbookair/...
jeehtoven - Ответить
I ordered a replacement battery for $75 (shipping included) and 3 days later the switch is done (thanks for this easy guide!). Now, my wife's MBA is free from power cord again! It is a no brainer!
Mathieu Brassard - Ответить
I have bought the This replacment a1245 battey - A1237 and A1304 Battery
thanks for the install guide
BatteryJohn - Ответить
Well, that was easy. Now I can us my macbook air again without wires.
ppatel - Ответить
Did it in minutes...cheaper than authorized Apple guy was charging me...machine works like a charm again. Thanks MJ & iFixit. :)
Jitendra B Amesar - Ответить
Other guides mention from late 2010 onwards Apple use 5-star anti-tamper screws on the bottom lid. So such a bit is useful on those later models.
Gunnar Forsgren - Ответить
Any idea where to buy the two screws of the battery? One of mine is spread and unusable.
Francesco Emanuele Bucci - Ответить
Thanks for the guide. How long will this batteries give me? None of the site tell you.
Thanks again for the video.
Peter - Ответить
The battery change is very simple. But now the battery isn't loading. The macbookair sees the battery but say not loading. loader was good and gives a green light.
who can help me? peter.vd.raad@hetnet.nl
Peter vd Raad - Ответить
I think one should not forget before attempting to open the back of the computer is to shut down the computer.
Hiro Hara - Ответить
Thanks for this guide and all the others. iFixit it literally the greatest site in the universe. People come here from other galaxies just to watch the video guides. MJ is beautiful and she knows her stuff so she makes doing a fix much easier with her comforting personality.
Lemon Bailey - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 29
За последние 30 дней: 161
За всё время: 232,028
