Введение
The heat sink helps keep the processor cool and happy.
Выберете то, что вам нужно
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Disconnect the battery connector by pulling it straight out of its socket.
Remove the following nine screws securing the battery to the Air:
Four 2.9 mm Phillips.
Four 3.8 mm Phillips.
One 7.2 mm Phillips.
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
Pull the audio out ribbon cable off the adhesive securing it to the upper case.
Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
Remove the four Phillips screws securing the hard drive assembly to the upper case:
Two 4.7 mm screws.
Two 3.9 mm screws.
Use the tip of a spudger to pull the fan cable connector straight away from its connector on the logic board.
One 5.9 mm Phillips screw.
Two 1.9 mm Phillips screws.
One 1.9 mm Phillips screw.
One 5.0 mm Phillips screw
Five 1.9 mm Philips screws.
One 2.5 mm Phillips screw.
Еще один человек закончил это руководство.
