Введение
How to remove the hard drive, along with its cable and bracket from your computer.
Инструменты
Запчасти
Детали не указаны.
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
2 участников успешно повторили данное руководство.
