MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement
Выберете то, что вам нужно
  1. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement, 5 pins Magsafe connector and cable: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Desoldering Pump
    $3.99
    • Tools required:
    • A decent soldering iron
    • Wire cutters
    • Desoldering pump
    • A big heavy-duty spudger
    • A pair of snap-ring pliers for use with external snap-rings. Really any long-nose pliers would do, this is just perfect for the job if you happen to have a pair :-)
    • Super glue
    • 1 or 2 small clamps
  2. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 2, изображение 1 из 3 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 2, изображение 2 из 3 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 2, изображение 3 из 3
    • Open the cord winding flaps.
    • Heat the power brick's plastic casing with a hair dryer, and/or run a razor blade along the seam between the two halves of the casing, in order to weaken the adhesive. This will make it easier to pry the case open.
    • Insert your pliers and pry slowly. (Make sure they stay seated in the inside corners, or you may injure yourself or gouge the case.)
    • The cord winding flap will fall out.
    • Do the same on the other side.
    • Work slowly!
  3. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 3, изображение 1 из 1
    • If your charger is never opened before, it would be difficult to pry it open. Try bench-vise tools to add power your needle nose plier
    • Handle of your needle-nose plier is laid upon the closed bench vise, insert into the casing, then roll the vise slowly.
    • The casing would be cracked and you can continue to next step
  4. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 4, изображение 1 из 2 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 4, изображение 2 из 2
    • Finish it by hand; you'll have to apply some force.
    • At some point, the case will crack open. (The edges are glued all the way around, and the interior metal sheeting may be glued to the case with a foam adhesive as well.)
    • The corner pieces inside the winding flaps, with their flat metal springs, may come loose as well; note their arrangement with springs pointing toward the cord, for reinstallation later.
  5. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 5, изображение 1 из 1
    • Carefully remove the inside from the shell.
    • Be careful not to touch any of the capacitor leads, or you may receive an electric shock.
    • If the inside sticks to one half of the shell, it's probably due to (a) glue around the edge of the A/C connector, and/or (b) foam glue between the inside and the flat of the shell.
    • Use a heavy duty spudger or other pry tool to pry the edge of the A/C connector from the shell, and carefully pry between the shell and the inside to break the foam glue.
    • Use only ESD-safe pry tools. Do not use metal pry tools or screwdrivers.
    • You may find the metallic sheeting breaks a little; that's okay, but try to minimize the damage!
  6. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 6, изображение 1 из 1
    • I like to insert a big spudger to make more room to work.
  7. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 7, изображение 1 из 3 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 7, изображение 2 из 3 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 7, изображение 3 из 3
    • Make sure you note the position of the positive and negative terminals.
    • Start by removing a bit of solder with the pump.
    • Separate the cables. It may require some force, so be careful not to break the board.
  8. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 8, изображение 1 из 2 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 8, изображение 2 из 2
    • The replacement cable should be tinned with solder before solder on the board; just put the leads in place and apply heat to install it.
    • Bending the wire tips 90 degrees helps with installation.
  9. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 9, изображение 1 из 1
    • Carefully put the power assembly back in the first half of the casing.
    • It will be a tight fit!
  10. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 10, изображение 1 из 1
    • Place the cable grommet in the proper position in the casing.
  11. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 11, изображение 1 из 1
    • Put the cord winding flappers back in position.
  12. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 12, изображение 1 из 1
    • Put some super glue on the cover.
    • Avoid the flap areas and the grommet area.
  13. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 13, изображение 1 из 3 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 13, изображение 2 из 3 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 13, изображение 3 из 3
    • You might want to wear gloves so as not to get excess super glue on your fingers.
    • Hold the flaps in place and install the other half of the casing.
    • It will be tight—be patient!
    • Make sure the flaps stay in place.
  14. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 14, изображение 1 из 2 MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 14, изображение 2 из 2
    • Clamp the casing together and give it a few hours for the glue to set.
  15. MacBook Power Cord 5-Pin MagSafe Connector and Cable Replacement: шаг 15, изображение 1 из 1
    • Just like new!
Заключение
Apply and repeat to all your friends victim of faulty cable ;-)
182 человек успешно провели ремонт по этому руководству.
Pierre Merineau
Участник с: 02/10/10
3 249 Репутация
1 руководство автора
50 Комментарии к руководству
This guide was very helpful in figuring out what needed to be done and how to do it. I don't have access to a lead pump so I ended up removing the old wires and then soldering the new ones on top of the remaining solder. So far it's working just fine!
Wildlife Ecology - Ответить Поделиться
I wasn't able to open my charger, even when using heat, the pliars as shown here and even a knife. As the damage to my cable was a few inches from the charger I just cut the cord and soldered a new one to the end. Cable looks a bit ratty but you could use white tubing to place over the top.
This guide is great and would definitely use it if possible =)
Ben Winkler - Ответить Поделиться
Try using bench vise with needle-nose plier
ridwan - Поделиться
You certainly need to knife thoroughly along the seam for it to open; after which you need to pry slowly with a pair of pliers by applying a considerable amount of force. Prudence is necessary when applying force because brute force will likely damage the casing; that means if you think adding more force will break the casing, it probably will. Knife it some more and then try again. Patience is *key*.
nawkwan - Поделиться
I managed to open the casing without breaking it *but I did break my pliers in the process. lol
https://imgur.com/a/C73wvBr
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 25
За последние 7 дней: 144
За последние 30 дней: 555
За всё время: 315,931
