MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement
Выберете то, что вам нужно
    1. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Magnetic Project Mat
      $19.95
      • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
      • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
      • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.7 mm screws
      • Four 3.4 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Open a gap using a suction cup: шаг 2, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Open a gap using a suction cup: шаг 2, изображение 2 из 2
      • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
      • Lift the suction handle to create a slight gap between the lower case and the chassis.
      Спросите у FixBot
    3. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Separate the clips: шаг 3, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Separate the clips: шаг 3, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Separate the clips: шаг 3, изображение 3 из 3
      • Insert one corner of an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the nearest corner and halfway up the side of the case.
      • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
      Спросите у FixBot
    4. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 4, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 4, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 4, изображение 3 из 3
      • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
      Спросите у FixBot
    5. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 5, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 5, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 5, изображение 3 из 3
      • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
      • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
      • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
      Спросите у FixBot
    6. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 6, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 6, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 6, изображение 3 из 3
      • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • Pull first at one corner, then the other.
      • Pull to the side—not up.
      • This can require a lot of force.
      Спросите у FixBot
    7. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Remove the lower case: шаг 7, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Remove the lower case: шаг 7, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Remove the lower case: шаг 7, изображение 3 из 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      Спросите у FixBot
    1. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Uncover the battery connector: шаг 8, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Uncover the battery connector: шаг 8, изображение 2 из 2
      • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
      • Remove the tape.
      Спросите у FixBot
    2. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 9, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 9, изображение 2 из 2
      • Gently peel back the small piece of tape covering the battery board data cable connector.
      • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
      Спросите у FixBot
    3. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 10, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 10, изображение 2 из 2
      • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
      Спросите у FixBot
    4. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 11, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 11, изображение 2 из 2
      • Disconnect the battery board data cable by sliding it out from its socket.
      • Slide parallel to the logic board, in the direction of the cable.
      Спросите у FixBot
    5. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 12, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 12, изображение 2 из 2
      • Fold the battery board data cable to the side and out of the way.
      Спросите у FixBot
    6. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 13, изображение 1 из 1
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      Спросите у FixBot
    7. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Disconnect the battery: шаг 14, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Disconnect the battery: шаг 14, изображение 2 из 2
      • Use a spudger to gently lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
      Спросите у FixBot
    1. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Remove the trackpad connector screws: шаг 15, изображение 1 из 1
      • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
      Спросите у FixBot
    2. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 16, изображение 1 из 1
      • Remove the trackpad cable connector bracket with a pair of tweezers.
      Спросите у FixBot
    3. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Disconnect the trackpad: шаг 17, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Disconnect the trackpad: шаг 17, изображение 2 из 2
      • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
      Спросите у FixBot
    4. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Heat the trackpad cable: шаг 18, изображение 1 из 1
      • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
      • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
      Спросите у FixBot
    5. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Peel up the trackpad cable: шаг 19, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Peel up the trackpad cable: шаг 19, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Peel up the trackpad cable: шаг 19, изображение 3 из 3
      • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
      • Do not fold or tear the cable.
      Спросите у FixBot
    6. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement, Remove the trackpad screws: шаг 20, изображение 1 из 1
      • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
      • Two 4.3 mm screws
      • Eight 5.8 mm screws
      Спросите у FixBot
    7. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 21, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 21, изображение 2 из 2
      • Swing the display open slightly to access the trackpad.
      • Carefully thread the trackpad ribbon cable out through the hole in the MacBook Pro's frame.
      Спросите у FixBot
    8. MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 22, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 22, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Trackpad Replacement: шаг 22, изображение 3 из 3
      • Remove the trackpad assembly.
      • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
      • Make sure your new trackpad has a ribbon cable installed before reassembly. If necessary, transfer the old cable, or install the one your new trackpad came with.
      Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
6 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
168 737 Репутация
Автор 437 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 32
За последние 30 дней: 149
За всё время: 8,839
