Введение
Use this guide to replace the fan.
Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$16.96
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
Carefully remove the rubber fan bumper from the edge of the heat sink.
Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
Remove the following screws securing the heat sink to the logic board:
One 2.7 mm T5 screw (silver)
Four T5 screws (black)
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
Use the tip of a spudger to flip the tab on the fan's ZIF connector.
Carefully pull the fan cable straight out of its socket.
Remove the following screws securing the fan to the upper case:
One 5.0 mm T5 Torx screw
Two 3.6 mm T5 Torx screws
Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
83 человек успешно провели ремонт по этому руководству.
17 Комментарии к руководству
Very good instructions, just completed the fan replacement, no issues -
Fantastic instructions, brilliant depictions for assistance. Thank you!
I completed this guide and it was brilliant, so thank you Andrew Optimus Goldberg and your contributors! I have a question about the Macbook's heat post-installation of a new fan.
I replaced the fan last night, and put everything back together. Today, the new fan is responding well under activities that would previously make the fan extremely loud and cause intense heat to build up on the bottom right of the Macbook: so far so good.
However, it seems heat is now being distributed to the keys and directly below the screen, and I can even feel it underneath the trackpad, and this is from simply turning the Macbook on with no applications straining the CPU.
Is this something to worry about? Have I possibly made a mistake in my installation, or is this normal for an ordinary working fan?
Thanks for any help that may be given. Appreciated
Is the fan you replaced the original one with the exact same model? While im no expert on this stuff my guess would be that it distributes air differently. I hope it works out for you though.
Nikolay -
Just completed the fan replacement. Great clear instructions. No issues. Thank you so much.
