Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace the left speaker.
When operating normally, during most of the guide it will be on the right, as your laptop will be upside down.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
Remove the following screws securing the left speaker to the upper case:
One 5.7 mm T5 Torx screw
One 6.5 mm T5 Torx screw
One 3.8 mm T5 Torx screw
Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
52 участников успешно повторили данное руководство.
4 Комментариев
Does anyone know the RMS/wattage of the speaker?
Excellent clear instructions. On my MacBook the cover screws were marked on the threads with white for the long ones and blue for the short. Since I couldn’t source a replacement speaker I repaired the existing one using contact glue as described by Earl Maliki on YouTube…it works; no more rattles. The sound is now lo-fi for the left speaker but good enough for speech and I never listen to music without a Bluetooth speaker. Total cost: 24 Swiss francs for a screwdriver set with a P5 pentalobe head. Much better than the 167 fr and 2 weeks in the shop I was quoted locally for repair.
Hi there,
thank you for the detailed instruction. Used it to replace rattling speakers in a “customer” laptop (I work in the Repaircafé in Bern, so not a commercial operation).
Cheers, J.
Very easy to follow instructions, the screw ID's were the biggest help, since Apple loves to rummage in their toolbox for a different one for each hole. Had a bit of trouble re-installing the speaker due to speaker cable being 'new', but with a bit of patience I got it to lie flat.
