Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
Remove the I/O board cable bracket.
Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
Lift the logic board end of the I/O board cable straight up to bend it out of the way.
Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Carefully pull the DC-In board connector straight out of its socket on the logic board.
Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
Pull the microphone cable out of its socket on the logic board.
Use the tip of a spudger to flip the retaining tab on the ZIF connector.
Pull the keyboard cable straight out of its ZIF socket on the logic board.
Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
Fold the cable out back over the battery to clear the way for the logic board.
Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
Remove the logic board.
Еще один человек закончил это руководство.
