Выберете то, что вам нужно
Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
Lift the trackpad cable up off the battery to separate it from the adhesive securing it.
Pull the trackpad cable straight out of its ZIF socket on the trackpad control board.
Remove the single 3.7 mm T5 Torx screw securing the battery board to the upper case.
3 человек успешно провели ремонт по этому руководству.
3Комментарии к руководству
Why remove the screw in step 5?
Step 5: Remove the single 3.7 mm T5 Torx screw.
Step 6: Re-screw single 3.7 mm T5 Torx screw.
