Введение
This guide contains instructions for using the old-style iFixit adhesive remover with separate bottle and syringe, which is no longer sold. For the updated version, click here.
Use this guide to safely remove the glued-in battery from your MacBook Pro with the help of an iFixit battery replacement kit. The adhesive remover in your kit will dissolve the adhesive securing the battery, allowing you to remove it with ease. The battery is made up of six distinct cells, four of which are adhered to the upper case.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
For your safety, drain your MacBook Pro's battery before you begin this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured.
Note: The solvent used to dissolve the battery adhesive can damage certain plastics, such as the MacBook Pro's plastic speaker enclosures. Take care when applying the solvent.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
The lower case is connected to the upper case at the center, with two plastic clips.
Remove the plastic cover adhered to the battery contact board.
Remove the following screws securing the battery connector board to the logic board:
Two 2.8 mm T6 Torx screws
One 7.0 mm T6 Torx shouldered screw
Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
Carefully lift the battery connector board up off the logic board.
It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
Move the SSD cable connector out of the way.
Wedge the pointed end of a spudger beneath the right speaker cable connector.
Gently pry the right speaker cable connector up off from its socket on the logic board.
Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
One black 6.8 mm screw
One silver 6.3 mm screw
One black 4.9 mm screw
Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
Wedge the tip of a spudger beneath the left speaker cable connector.
Gently pry the left speaker cable connector up off from its socket on the logic board.
Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
Now that your MacBook Pro is fully prepped, it's time to prep yourself.
Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
Do not wear contact lenses without eye protection.
Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
Open your container of adhesive remover.
Fill the syringe included in your kit with a small amount (approximately 1-2 milliliters) of adhesive remover.
Refill your syringe as needed throughout the rest of this procedure.
Apply a small amount of adhesive remover (approximately 1 ml) evenly under the edge of the leftmost battery cell.
Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
Insert the spudger along the left-hand side of the leftmost battery cell.
Run the spudger up along the left side of the leftmost battery cell.
Slightly pry the leftmost battery cell to release it from the adhesive.
Repeat the above steps to separate the adjacent battery cell from its adhesive:
Apply a small amount (about 1 ml) of liquid adhesive remover under the battery cell.
Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
Insert the flat end of a spudger underneath the larger leftmost battery cell.
Carefully wedge the spudger inwards, being careful to not damage the battery cells.
Pry the larger leftmost battery cell up off the upper case.
Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
Leave the battery cells resting on top of the upper case as shown in the third picture.
Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
Remember to add about 1 ml of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
Lift the battery as a whole up out of the upper case, and remove the battery.
With a little luck, you can slowly pull out each strip of adhesive with your fingers.
Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
Calibrate your new battery before using it: allow it to drain overnight, then charge it to 100% and drain it again until your MacBook Pro shuts down automatically. Charge it again and use it normally.
2 участников успешно повторили данное руководство.
Один комментарий
Step 14 and Step 18 (disconnecting the speakers) are not really useful. But there should be a reason I didn’t catch for these steps. Thank you by the way, it was really clear and it worked perfectly!
