Введение
Use this guide to replace the lower case.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
5 участников успешно повторили данное руководство.
Один комментарий
Tengo una Macbook Pro Retina Display Late 2012. Pero al leer el tutorial noto que los tornillos que dices son dos de 2.3 mm y los demas de 3.0 mm.
Pero en mi macbook todos son de 1.2 mm. Porqué?
